Teraz jest 24-06-2026, 09:43
 Tytuł: Pytanie od kolegi z Australii
PostNapisane: 26-06-2007, 17:04
Site Admin
Model: GTTI
Rok: 0
I wish to buy the fuel injection intake setup from a 3 cyl 993cc , 6 valve single overhead cam daihatsu charade.
I need the complete intake including throttle body, Injectors and fuel rails.
I believe the engine was called a cb90 and was on Daihatsu charades from 88-92 maybe longer.
Can you put me in contact with someone who can supply me with these units and is willing to freight to me in Australia
Thanx
Dave Franklin
kontakt: thefranklins2002@bigpond.com.au
Jak by ktoś chciał mu pomóc :))
Niech moc będzie z wami :)
PostNapisane: 26-01-2009, 15:36
Dołączył(a): 26-01-2009, 06:58
Hi Mis
The CB90 engine is also available in Germany or Austria, they are a little bit different to each other (German version vs. Austrian version) but I think you can use it as you like. The German version did not have a catalytics but the Austria version does have it.
You dont need to go to Australia to get a CB90 engine.
But maybe it is easier and better for you to buy a complete car, maybe with a CB61 engine. This will also fit into your car. So it use a carburator AND it is turbo charged up to 68HP, so it is easier for you and you got more power.
Regards
Rainer
